1997 Chevy Blazer WILL NOT MOVE
1997 CHEVROLET BLAZER
LJSMOKIN
Drive Train Axles Bearings problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic
MY QUESTION IS THERE IS IS LOT OF RATTLING SOUNDS COMMING FROM THE DRIVE SHAFT AREA.
WHEN I PUT THE VEHICLE IN GEAR IS WHEN THE NOISE STARTS. THE VEHICLE WILL NOT MOVE NOW.
CAN YOU HELP ME FIGURE IUT WHAT THE PROBLEM IS?
Oct 22, 2009 at 10:43 AM
BMRFIXIT
  • 19,053 POSTS
Place it in Park and try to push the truck can you
and if so check drive shaft and rear differential
if 4X4 make sure its not in neutral or stuck in between gears
Oct 22, 2009 at 12:44 PM
