I just replaced my battery and the volts are only at about 5. what is the issue?
Jul 20, 2009 at 11:08 AM
LOUT5369
✓Experienced Mechanic
Are you going by the gage on the dash,or a voltmeter,Check your battery connections First,make sure they are clean & tight,If you have a voltmeter disconnect the battery cables and check battery itself
