1997 Chevy Blazer voltage
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
TMSNOW22
I just replaced my battery and the volts are only at about 5. what is the issue?
Jul 20, 2009 at 11:08 AM
LOUT5369
  • 217 POSTS
Are you going by the gage on the dash,or a voltmeter,Check your battery connections First,make sure they are clean & tight,If you have a voltmeter disconnect the battery cables and check battery itself
Jul 21, 2009 at 4:27 AM
