while trying to start engine kicks back hard enough to strip the teeth off the flywheel.
Oct 18, 2009 at 9:48 AM
✓Experienced Mechanic
Have you checked timing? It sounds like it is too far advanced?
Oct 19, 2009 at 12:20 AM
ESTRNGY
MEMBER
You're right on the money. I think that I've solved the problem. Seems that the crank shaft position sensor goes a little crazy and advances the timing up to 50degrees resulting in a no start, backfire, engine
kickback conditions. GM makes a revised sensor that
corrects the problem. thanks again for quick responce
to my question.
Oct 19, 2009 at 5:03 AM
Let me know if it fixes the problem.
Oct 19, 2009 at 6:25 AM
ESTRNGY
MEMBER
YES the problem is fixed. Installed a new crankshaft sensor timing is back to normal runs like new again.
Oct 23, 2009 at 7:29 PM
Sounds great. Glad you got it fixed. Let us know if you have questions in the future, and thanks for using 2carpros.com
