1997 Chevy Blazer Starting problems
JEREMY_88
Engine Mechanical problem
1997 Chevy Blazer Four Wheel Drive Automatic
Have a 1997 blazer that will not start. it cranks and gets spark. the battery is good and has fuel in tank. any solution.
Feb 7, 2009 at 6:40 AM
  • 110,251 POSTS
Hi:
If you are getting spark, you need to check for fuel pressure. The pump may be bad or have a clogged fuel filter. Go to this site:
https://www.2carpros.com/dia/test_fuel_pressure.htm
It is a video from this web page that explains how to check fuel pressure. You should be able to rent or borrow a a pressure gauge at most nationally recognized parts stores.
Let me know if this helps.
Jan 29, 2021 at 4:49 AM
JEREMY_88
that was what i thought too but the fuel pump is good and there is plenty of fuel pressure.
  • 110,251 POSTS
If the fuel pressure is good and you have good spark, then you either have low compression or the timing is out. If you haven't performed a pressure test, it may be low enough to cause the problem. Also, if you spray starting fluid in the throttle body, will it start and run for a few seconds?
