1997 Chevy Blazer starting
FIREFIGHTER9002
Electrical problem
1997 Chevy Blazer 6 cyl All Wheel Drive Automatic
i am unable to start my blazer
i have full voltage in the battery
i have tightened the cables up on the battery and i have tried jump starting and rapping on the starter
i am when i turn the key over i get one suttle click and thats it no attempts to turn over at all
Jul 3, 2010 at 10:55 AM
  • 75,988 POSTS
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be a blown fusible link the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Jul 3, 2010 at 10:57 AM
