1997 Chevy Blazer STARTING
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
MONIE_SALAS
WHEN I TRY STARTING MY CAR IT TAKES SOMETIMES OVE 10 TIMES FOR ME TO TURN THE KEY BEFORE IT TURNS ON. HOWEVER IT DOESNT EVEN TRY TO TURN ON WHEN I FIRST TURN THE KEY IT JUST CLICKS AND I HAVE HAD THE BATTERY CHECKED AND IT IS NOT THE BATTERY WHAT COULD IT BE?
Dec 10, 2009 at 2:54 AM
JDL
  • 16,098 POSTS
welcome to the forum. When the problem occurs, I'd check the circuits at the starter relay. Use a testlite. Voltage to load side of relay is hot all the time. Voltage to coil side of relay goes hot with the key in the start position. If that checks out, I pull the starter and have it tested.
Dec 10, 2009 at 3:25 AM
MONIE_SALAS
OK.. I CAN TAKE IT TO ANY SHOP AND THEY CAN DO THIS FOR ME? HOW MUCH DO YOU THINK A STARTER COSTS IF I NEED TO GET A NEW ONE?
Dec 10, 2009 at 3:51 AM
JDL
  • 16,098 POSTS
hi, if you can't or won't do any testing, I don't know how to help? There are many online partsbooks, autozone--napa-- rockauto.
All you need is testlite on the relay circuits, not rocket science. I'll help you for free, the shop won't do that. Have a good day.
Dec 10, 2009 at 5:12 AM
