Recently installed an IC Dynamics remote start (following their instruction), after which the check engine light is on. Codes given are P0785 shift timing solenoid malfuntion, P1860 solenoid electrical fault, and P0740 converter clutch circuit malfuntion. Note that no wiring has been spliced or cut, this was just parralel connections to the facory harness. The remote start funtions and vehicle runs but noticed the check engine and shifting troubles.
SPONSORED LINKS
Thursday, December 11th, 2008 AT 2:32 PM
