1997 Chevy Blazer Odd fluid leak?
KOBIDOG
Steering problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic 66.00 miles
I have been trying to find a leak in my power steering system. It does not leak when the car is running just when you shut it off. Pump does not leak and hoses appear not to be leaking. Looks as though it is leaking between the grill and the radiator. Does a 97 s10 Blazer have some kind of cooling system for the Power steering?
Oct 20, 2008 at 4:18 AM
RHALL77
  • 3,361 POSTS
check and see if the steering gear is leaking. is the leak on the drivers side.
Oct 21, 2008 at 12:52 AM
