1997 Chevy Blazer NO FUEL AT FUEL RAILS
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
DGE396
I REMOVED DASH TO REPLACE HEATER CORE AND HAD TO REMOVE A LOT OF ELECTRICAL CONNECTIONS AND AFTER REPLACE EVERYTHING ENGINE WOULD NOT START NOT RECEVING FUEL AT FUEL RAIL ARE THEY A WIRE BEHIND DASH THAT GOES TO FUEL PUMP THAT MAYBE I DIDNT HOOK UP
Jan 14, 2009 at 9:59 AM
RHALL77
  • 3,361 POSTS
check and make sure your fuses are good. you may have blowen one when you had everything apart
Jan 14, 2009 at 10:33 AM
DGE396
checked fuses all ok
Jan 15, 2009 at 11:33 PM
