1997 Chevy Blazer misfire code
146,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGANTHONY
I have a 97 blazer s-10. I recently had it checked out at autozone with their computer anylizer that gives you codes for the service engine light and it said that there is a mis fire. I recently changed the spark plugs not even a year ago and the wire s are tight on the plugs, is there any other advice you can give me on wht else I may be able to check to find out what i have to fix or replace.
Thank you
Dec 15, 2009 at 2:56 AM
SWILLIAMS
  • 597 POSTS
Without the actual code it is a shot in the dark.
If you have a random multiple misfire it could be a LOT of things.
Plugged fuel filter, clogged fuel injectors, bad wires, plugs, cap/rotor, bad drive gear on the distributor.
Get the actual code and you can narrow it down faster.
Dec 17, 2009 at 3:48 PM
