1997 Chevy Blazer lights
136,000 MILES • 6 CYL • 4WD • AUTOMATIC
WHITTY
I was needing some help with mu wifes truck when you turn on the right turn sig, all the lights flash,but when you have all the lights in the right does not work
Jan 12, 2008 at 7:59 AM
MASTERTECHTIM
  • 4,750 POSTS
you have the incorrect bulb on the right side. double check, i bet you will find you have put a 1 filament bulb where there should be a 2 filament bulb. let me know if this helps.
Jan 12, 2008 at 8:08 AM
