1997 Chevy Blazer fuel problem???????
128,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOSHUA CUPPETT
  • 6 POSTS
i got a 97 blazer and am having some trouble but who doesn't with that model well problem is that it seems to loose most to all power when gas is pushed to the floor and only then i mean i can git that thing to do 100 as long as i ease on the gas but as soon as i punch it the engine just bogs out but stays running ......o yea most of the time it wont start with help from starter fluid ....{fuel pump ,spiders ,regulator ????? help!!! going nuts and broke ...thanks
Mar 30, 2010 at 6:45 AM
RHALL77
  • 3,361 POSTS
do you have a check engine light on? when was the last time it has been tuned up
Mar 30, 2010 at 7:59 AM
JOSHUA CUPPETT
  • 6 POSTS
no check light that why i thinks its mechanical and tune up last month
Mar 30, 2010 at 8:57 AM
RHALL77
  • 3,361 POSTS
have you checked fuel pressure to see if there was enough at the injector
Mar 30, 2010 at 9:08 AM
JOSHUA CUPPETT
  • 6 POSTS
no cant find a pressure gauge that will work on a 97 only per 96 but holds pressure at filter and perg vulvae no strong smell of gas eather and i dont know if this makes diff but it is a( w ) moter
Mar 30, 2010 at 9:23 AM
JOSHUA CUPPETT
  • 6 POSTS
[quote:b3500b7bbc="joshua cuppett"]no cant find a pressure gauge that will work on a 97 only per 96 but holds pressure at filter and perg vulvae no strong smell of gas eather and i dont know if this makes diff but it is a( w ) moter[/quote:b3500b7bbc]
Mar 30, 2010 at 11:40 AM
JOSHUA CUPPETT
  • 6 POSTS
PLEAS HELP I NEED ANSWERS
Mar 30, 2010 at 1:15 PM
RHALL77
  • 3,361 POSTS
what do you mean it wont fit. it's the smae valve that is on all gm vehicles. if you cant find it or it doesnt have one, then i suggest taking it to a shop that has the equipment to test fuel pressure
Mar 31, 2010 at 1:12 AM
