1997 Chevy Blazer Fuel Filter
1997 CHEVROLET BLAZER
DLBCANCER
Engine Performance problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic
How to install fuel filter for 97 chevy blazer
Apr 6, 2009 at 10:52 AM
JDL
  • CERTIFIED EXPERT
  • 16,098 POSTS
Loosen the gas cap, make sure there is no pressure on the fuel system, usually after the vehicle sits overnight without the key being cycled, there isn't much pressure, double check about the pressure though.
Threaded on one end, quick connect fitting on the other. I have used needle nose pliers to get the fitting loose. It's probably best to use the proper tool, the autostores sell them.
Apr 6, 2009 at 11:17 AM
