1997 Chevy Blazer front shaft
BINBOY66
Drive Train Axles Bearings problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic
how do i get the drive shaft off on the front,do i have to take the exhaust off ? ty
Nov 27, 2009 at 4:29 AM
  • 110,246 POSTS
Are you refering to the drive shaft? If so, you should be able to remove it without removing the exhaust. Can you explain what is happening?
Nov 28, 2009 at 12:04 PM
BINBOY66
when i remove the bolts from the front yoak it drops down,but then i wont do down far enought to pull it out of the transfercase because it hits on the cross over pipe
Nov 29, 2009 at 5:27 AM
SWILLIAMS
  • 597 POSTS
It should come out without dropping the exhaust. I have pulled the one on my '97 and others without dropping the pipe.
Has the crossover pipe been replaced with an aftermarket?
Nov 30, 2009 at 6:20 PM
