1997 Chevy Blazer Front end makes popping noise when turnin
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
JQPEREZ
Front end makes loud popping noise when pulling(turning) in and out of drive way or making abrupt stops. I think it is the a-arm but not sure. Any ideas?
Sep 10, 2010 at 12:44 AM
MMPRINCE4000
  • 8,548 POSTS
A arm, idler arm, pitman arm.
Raise car, put on stands, grasp tire and push/pull both horizontally and vertically, if you have movement you would have to check all the above and ball joint, tie rods.
Sep 10, 2010 at 1:20 AM
