1997 Chevy Blazer fan replacement
121,000 MILES • 6 CYL • 4WD • AUTOMATIC
ERIC18360
ok, so the fan clutch is threaded to the water pump. what is the best way to keep the shaft from turning while trying to unscrew the assy?
Jul 4, 2008 at 2:19 AM
SWILLIAMS
  • 597 POSTS
Leave the belt on and give the wrench a good whack to break the fan free. If the belt is alredy off you can use a strap wrench.
Jul 5, 2008 at 3:40 AM
