Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Engine Cooling
Cooling Fan
Clutch
Replace/Remove
1997 Chevy Blazer fan replacement
1997 CHEVROLET BLAZER
121,000 MILES • 6 CYL • 4WD • AUTOMATIC
ERIC18360
MEMBER
1 POST
ok, so the fan clutch is threaded to the water pump. what is the best way to keep the shaft from turning while trying to unscrew the assy?
Jul 4, 2008 at 2:19 AM
SWILLIAMS
Experienced Mechanic
Leave the belt on and give the wrench a good whack to break the fan free. If the belt is alredy off you can use a strap wrench.
Jul 5, 2008 at 3:40 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
