1997 Chevy Blazer EVAP System
195,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKEWEST
Code reader says it's an EVAP system issue. (I believe it was a 33, but not positive anymore.)
Symptoms:
- Poor fuel mileage
- In hot weather only (so far), fuel seems to get choked off after driving for a while. After letting the car sit for a 30+ minutes, it will fire right up and run normal as before.
I appreciate any help I can get.
Jan 22, 2010 at 6:05 AM
VONHINER
We have a 97 and experienced the no starting problem but after letting it sit it would finally start. If you have the same problem, it only gets worse until it won't start at all. We replaced the fuel pump and it took care of it. It was pricey(800.00 installed) but the part is expensive
Jan 25, 2010 at 2:59 PM
