1997 Chevy Blazer error code po440
JAVONIE031
Computer problem
1997 Chevy Blazer 6 cyl Two Wheel Drive Automatic
after i put on a new fuel pump about a week later my check engine soon light came on, one of the lines came off the fuel pump and i put it back on but the light is still on every thing is back the way i took it off and tighten, so what came it be?
Apr 12, 2010 at 9:58 AM
BMRFIXIT
  • 19,053 POSTS
Check hose on top front tank
If fuel pump gasket and all line on and correct
Next step should be a smoke test as that should show the leak
Good luck
Apr 12, 2010 at 10:07 AM
