1997 Chevy Blazer Engine stalls sometime at stop light or w
MCLAUGHC
  • 1997 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 80,000 MILES
Engine stalls sometime when coming to a stop at stop light, it idles fine, then all of a sudden it shut off, turn the ignition and starts right up, runs fine. Happens maybe twice a day, I think it has to do with the fuel. Not electrical, just installed a new fuel tank a month ago, we can elimnate that, maybe fuel pump going bad?
Thursday, October 9th, 2008 AT 11:21 AM
KERENSELF
  • 54 POSTS
Intermittent issues like this can be hard to diagnose. - Although late-model GM trucks are known for fuel pump issues, I don't think I would go to the trouble of replacing it just yet.
If your service engine light is on, the onboard computer has picked up SOMETHING. Have the codes read at your local parts store.
If the light is not on, I would test the fuel pressure. Specs for this will be in a service manual, the most common being Haynes or Chiltons.
I also wouldn't count out the fuel pump relay.
Your best chance of figuring it out lies in duplicating the problem.
Good luck!
- Keren
Monday, October 13th, 2008 AT 8:30 PM
