CHECK THE BUTTERFLY IN YOUR THROTTLE BODY, MAKE SURE YOU DONT HAVE CARBON BUILD UP, USE THROTTLE BODY CLEANER IF SO, CHECK THE VACCUM LINES ON THE CAR ALSO, SPRAY THE CLEANER ON THE LINES IF YOU HEAR A DIFFERENCE IN THE IDLE THEN YOU KNOW YOU HAVE A LEAK, BUT CHECK INSIDE THE THROTTLE BODY FIRST. GOOD LUCK!
Tuesday, October 21st, 2008 AT 9:46 PM
