1997 Chevy Blazer Engine Removal
241,523 MILES • 6 CYL • 4WD • AUTOMATIC
WRIGHT2052
I need to know how to access the drive plate to torque converter bolts so that I can separate the engine from the transmission. The transmission does not have a torque converter cover but does have one inspection port at the bottom. Can you tell me how to access these bolts?
Oct 21, 2008 at 11:48 AM
MASTERTECHTIM
  • 4,750 POSTS
you have to remove the aluminum cover to gain access to torque converter bolts, you will also have to remove the starter motor and the angle braces that bolt to the cover. you will also need to lower the y pipe on exhaust to remove inspection cover. hope this helps
Oct 21, 2008 at 11:51 AM
