1997 Chevy Blazer engine no run shifter stuck in park no tu
76,000 MILES • 6 CYL • 4WD • AUTOMATIC
TPCHEVGUY
yesterday when driving at 25mph in rain I tried to stop ABS came on stopped then blazer stalled ,put it in park tried to start, started after about 6 tries,drove 4 miles and parked.Came out and tried to start about 2 hours later, cranks but no start , do not hear pump running.Also will not come out of park , and turn signals do not work??All fuses on left side of dash ok(no.9), swapped relays in glovebox and three along firewall with other ones from just junked vehicle.What if any relay connects turn signals and fuel pump and floor shifter solenoid together???The guages or idiot lights do not light in run position.All other electrical systems appear normal??Blazer ran and everything worked fine before??
Aug 29, 2009 at 8:51 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check out 16ga black fusible link at junction block left rear of engine compartment.
Let me know
Thanks for donate
Aug 30, 2009 at 7:29 AM
TPCHEVGUY
I checked all five fusible links are good at junction box, also the one at the pos batt term is good.In addition fuses #16 (turn signals) and fuse #4 (guages) have no power to them. Nothing appears unplugged or disconnected under hood or under dashboard???thanks
Sep 1, 2009 at 2:00 PM
DOCFIXIT
  • 18,828 POSTS
Power to fuses # 5,10,22? IF no power is supplied from ignition switch.
Sep 2, 2009 at 7:32 AM
TPCHEVGUY
no power to #5, #10, or #22,only power to radio, wipers, and radio with key in run position.....bad ignition switch??Is this common to s10 Blazers??
Sep 2, 2009 at 11:02 AM
DOCFIXIT
  • 18,828 POSTS
Don't know if common problem but that's what powers all the stuff you don't have power to.
Sep 3, 2009 at 8:32 AM
