1997 Chevy Blazer emergency brake light stays on
1997 CHEVROLET BLAZER
88,000 MILES • 6 CYL • 4WD • AUTOMATIC
LINDYLOU44
emergency brake light will not turn off, the emergency brake lights were not used...the light just came on and stays on???
Sep 20, 2009 at 9:27 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
faulty park brake sensor located at base of park brake assembly will cause this issue
Apr 24, 2019 at 7:06 PM
AJVANDYKE
  • 36 POSTS
Sometimes if your brake light will stay on its an indicator that your brakes are low and they need to be replaced (the more worn down your brake pads or shoes get the more fluid in the master cylinder is required to compress the pads when in use) Check the fluid in your master cylinder and if its low. Check your brakes
Apr 24, 2019 at 7:07 PM
