1997 Chevy Blazer Door Chime
111,350 MILES • 6 CYL • 4WD • AUTOMATIC
CALIIANGEL
i pulled into a parking space this morning and opened the door while the key was still in the ignition. As usual the door chime comes on and as annoying as it is i quickly pulled the door shut to turn it off but it kept going and going and going. I then turned the ingition back on and the chime stopped. as soon as I turn the ignition off- even with the door shut- the chime started up again. It will not shut off. I pulled the parking lamp fuse and it finally went off but now I have no parking lights. how do i fix the door chime problem and get my parking lights back?
Sep 22, 2009 at 4:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
try lubricating your vehicle's door latches with WD-40. the door ajar switch in one of the door latches is most likely sticking.
Sep 22, 2009 at 3:38 PM
