1997 Chevy Blazer brown sludge in radiator and oil
1997 CHEVROLET BLAZER
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
CALLEN954786
MEMBER
1 POST
I have brown sludge in my radiator and in my oil. What is the cause of this and how can I fix it?
Jun 29, 2009 at 9:45 AM
✓Experienced Mechanic
It sounds like there may be a head gasket problem allowing the two to mix. If you change the oil on a regular basis, and the coolant is kept up, my guess is a bad intake gasket or head gasket. You can check compression to test for a head gasket leak.
Jul 1, 2009 at 10:09 AM
