1997 Chevy Blazer Battery will not hold charge and engine w
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
EASYJESUS44
I recently asked a question , I thought my computer was bad cause when I coded my car it would say "failed"< I used an actron code machine(OBD2 Pocketscan)I changed the computer, and Tried to start with no result , my gages do not move when the key is turned , But THe battery was completely dead , I jumped the car and was there an hour and never got enough juice to get a good crank out fo the car . How much voltage does it take to make everything go ? Does the fuel pump require a certain amount of volts to run? Am I leaving anything out , when THe car stopped running , before it finally broke down, youd be driving down the road and al the dash light came on and there was a lull in the engine operation and then it seemed to snap back to normal , I havent ever had anything like this happen before. Continued the starter engages but is slow due to low volts...................
Dec 29, 2007 at 8:33 AM
  • 75,988 POSTS
Turn the ignition On disconnect the connector behind alternator and look for power at brown wire-do you have it? and also check the fuse link at the starter. Review the EWD below
https://images.2carpros.com/forum/automotive_pictures/12900_alternator_2.jpg
Dec 29, 2007 at 10:17 AM
