1997 Chevy Blazer 97 Blazer rear end squeak on acceleration
1997 CHEVROLET BLAZER
TAKODA12345
  • 5 POSTS
Noises problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic 160k miles
When I accelerate, I hear a loud squeak from the drivers side rear. Sounds like metal on metal. When I take my foot off the accelerator, it stops.
Is this a U-Joint or brake problem?
If it is the U-Joint, does a 97 blazer have a zirk fitting to grease? What is the recommendations?
May 1, 2008 at 1:20 PM
RHALL77
  • 3,361 POSTS
if it is a u joint i would suggest just replacing it. remove the drive shaft and see if it is tight.
May 2, 2008 at 2:02 AM
