1997 Chevrolet Blazer Vibration
LIONSFAN112000
I have a 97 Chevy Blazer 4wd w/4.3litre and the mileage is at 169000. I have had the truck for a short while and don't really know any history of this truck. The problem I am having is a vibration when I am accelerating. You can feel it more when speed is around 55mph or more. When driving at higher speeds the vibration goes away when I take my foot of the accelerator. There is probably a list of things that it could be, but where should I start?
Jun 13, 2007 at 2:51 AM
TOYPAR
  • 12 POSTS
That could be ALOT of things. I would start at the drivetrain, Bent rim, wheel balance, tire pressure, tire coindition, differential , now the motor, Diagnose the igntion system could be a bad plug, plug wire, cap, rotor, coil or timing. Fuel pressure, harmonic balancer, crank pulley, tensioner pulley and idler pulley. Good luck.
Jun 26, 2007 at 2:16 AM
MAPLELEAF_NUT
lionsfan112000...have you had any luck troubleshooting this problem...I have the same vechicle....with approx the same milage...and also the same problem......it vibrates at around 80-90 km/h for a little while....when I cruise up at 100-110km/h...all the vibration goes away....also..when it vibrates..if I let off on the gas..it goes away..it only vibrates under power...sounds very similar to your problem. I am suspecting the transmission...but I would really like to know how you have made out at your end.
thanks
Jul 16, 2007 at 1:48 PM
CHEVY22
  • 1,375 POSTS
CHECK THE U JOINTS AND THE CARRIER BRG BEFORE ANY MAJOR REPAIR THE CARRIER BRG IS AT THE SLPIT OF THE FRT AND REAR DRIVESHAFT
JIM
Jul 22, 2007 at 1:27 AM
WHATEVER987987
check out the u joints first.. i've heard that to actually work from what sounds to be the same problem. i have the same problem now and will let u know how it goes soon as i get money to try.
Apr 3, 2013 at 7:28 AM
u joints are the first stop here. i bet one is either locked up or very loose
Apr 20, 2013 at 12:53 AM
