Fuel pump runs and filter is clear. Gas shoots thru filter if started while disconnected. Have replaced fuel pressure sensor. car will start if given starter fluid but dies as soon as comsumed. I'm out of ideas. What is left to check. I do have spark if I remove plug wire. Could the oil pressure fuel gage switch be the issue?
Apr 11, 2010 at 4:10 AM
