1996 Chevy Blazer starter
PRESD81
Electrical problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic 195k miles
i HAVE REPLACED MY STARTER IN MY 96 BLAZER NOW THERE WAS TWO WIRES A BLACK WIRE WITH A METAL RIM AND A GREEN WIRE THAT WAS STRIPPED AND ALL IT WAS WAS ELECTRICAL WIRE THERE WASNT ENOUGH REACH SO I BOUGHT SOME GROUND WIRE FORM AUTO ZONE AND I ADDED ON TO IT NOW I TOOK THE GREEN WIRE AND I PUT THAT AROUND THE SMALL THREAD WITH THE SMALL NUT ONT HE STARTER AND TOOK THE BLACK ONE AND MOUNTED IT TO THE BIGGER THREAD WITH THE BIG NUT, BUT NOW MY BLAZER SOUNDS EITHER ITS TURNING IN REVERSE OR GRINDING I DONT KNOW IF I WIRED IT WRONG OR IF I DIDNT I CANT FIND HOW THE TWO WIRES GO ONLINE, IW OULDNT BE ASKING IF I TOOK THE OLD STARTER OUT, IT WAS ALREADY OUT...CAN ANYONE PLEASE HELP ME?>
Aug 16, 2010 at 5:46 PM
  • 75,988 POSTS
There's shouldn't be a green wire there-the thick black wire goes on the big termnal and the smaller purple wire goes to the small terminal the rest whatever's left could be a fusible link wire that goes also to the big terminal unless you have 2-small terminal on the solenoid which is used for ignition bypass-
Aug 16, 2010 at 9:41 PM
