When I drive for about 40 minutes, the car will shut off and will not start untill it sits about 10 minutes, especially when you run the ac. It only happens when the weather is hot. I have changed the fuel pump, fuel filter, ignition module, coil, crankshaft sensor, rotor cap and distributor cap. When the car stalls it does not put out any code, plus the engine compartment is hot.
SPONSORED LINKS
Wednesday, June 17th, 2009 AT 10:12 AM
