1996 Chevy Blazer Running Rough
RLUND55
  • 1996 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 115,000 MILES
When coming to a stop, the engine seems to have a problem recognizing that it should be decelerating. Not sure if that is engine or transmission. It also idles rough at the stop and then hesitates when accelerating from the stop. It dies frequently during idle at a stop. The idle RPM seems low at 500-600 RPM. Otherwise seems to run well at higher RPM.
Tuesday, November 9th, 2010 AT 6:40 PM
SERVICE WRITER
  • 9,123 POSTS
Is there a check engine light on?
If so what codes?
Fuel injection unit and fuel pimps were common on these, but would not assume either are going to be relevent at this point.
Tuesday, November 9th, 2010 AT 8:05 PM
