1996 Chevy Blazer oil pressure gone.
1996 CHEVROLET BLAZER
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
AKANDO5959
My fiance was driving to work today, and she said that the oil pressure went all the way down, and now the car can't drive. Her step-dad said that it could be the oil pump, but not sure. What else can cause the oil pressure to disappear.
Apr 4, 2009 at 6:53 AM
JDL
  • 16,098 POSTS
Hello, what do you mean it won't drive, is the engine froze-up? Can you turn the crank by hand?
Apr 4, 2009 at 7:12 AM
AKANDO5959
My girl just told me that actually the car still has oil, but she hears a knocking noise when turning the car on. The car will crank up tho. She doesn't know if it is from the motor or not.
Apr 4, 2009 at 8:43 AM
JDL
  • 16,098 POSTS
Hi, I wish I had better info, but, I don't. Need to find where the noise is coming from. If it's internal engine, I'd have to take it apart. On some makes with a tapping noise, I have pulled the oil pan, looked for metal in the pan. Pull the valve covers, see if you can find anything.
My hearing is no good, with noises, I have to hunt and peck, see if I can find it.
Apr 4, 2009 at 9:20 AM
AKANDO5959
I will do that next, but one other thing is. She says that when the oil pressure dropped. The check gauge light came on, and is still on.
Apr 5, 2009 at 2:59 PM
JDL
  • 16,098 POSTS
Hi, that may be part of the original problem. If think there are any codes, you would need an obd11 code reader.
Apr 6, 2009 at 1:54 AM
