my 96 blazer has an oil pressuer of 40 psi when it is first started and cold but as the engine heats up the oil pressure drops the hotter it gets the lower the pressure gets until it is in the red when i give it gas it goes up the back down when i let off the gas I just put new head gaskets on it a new crank, oil pump and oil pressure sendind unit and it still does it why no it does not rap at all if i dont fix it will i have a problem later
Feb 6, 2008 at 8:53 AM
