The oil cooler lines are leaking badly. I researched this and it seems like it is a very common problem with the s-10 chevy blazer. I was told that you can take off the oil cooler and lines, that they really are not necessary. If not, I thought about taking hose clamps and rubber sheet and wrapping the crimps in the lines. Do you think this will work?
Oct 30, 2008 at 11:25 AM
