Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Engine
Symptoms
Gas in Oil
1996 Chevy Blazer oil
1996 CHEVROLET BLAZER
236,000 MILES • 6 CYL • 4WD • AUTOMATIC
COG7085
MEMBER
i have gas in my oil
May 19, 2009 at 7:45 AM
RHALL77
Experienced Mechanic
check and see if your central fuel injector or injector lines are leaking inside the upper intake. this is a common failure.
May 20, 2009 at 1:37 AM
COG7085
MEMBER
thank you i was thinking that fuel press regulator was at fault
May 20, 2009 at 4:54 AM
RHALL77
they leak 2, also double check that
May 20, 2009 at 6:38 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
