1996 Chevy Blazer no oil pressure
125,123 MILES • 6 CYL • 4WD • AUTOMATIC
NOOILPRESSURE
when I let off the gas at a stop sign my oil pressure gage goes to zero when I accelerate it goes back up same around turns...my oil level is acceptable what could this be?
Jun 6, 2008 at 10:47 AM
MERLIN2021
  • 17,250 POSTS
I would remove the oil sending unit, attach a test gauge, and check the pressure. if its 10 psi at idle, and 40- 60psi at 2000rpm all is well, if not, oil pump or engine wear is the reason. You can try a heavier oil as a temporary solution. If the pressure test is normal, replace the sending unit..
Jun 6, 2008 at 10:55 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:05134fd996="nooilpressure"]Engine Mechanical problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic 125123 miles
when I let off the gas at a stop sign my oil pressure gage goes to zero when I accelerate it goes back up same around turns...my oil level is acceptable what could this be?[/quote:05134fd996]
What do you mean by acceptable? It is either full or it needs oil. If you are a qt or more low then fill it and see what happens.
If all is good with oil level and it has been change on recommended schedule then it could be either the Oil Pressure Switch or the Oil Pump.
Switch is cheaper and easier to change.
post responses and results here....
Jun 6, 2008 at 11:00 AM
