1996 Chevy Blazer need help with breakes
LAURALOU0084
Brakes problem
1996 Chevy Blazer
we had a busted break line changed it during the bleeding of the breaks got no fluid out of the rear so retried several of times still nothing so we changed master cylinder 2 times and still nothing we blew out the lines and still can not get nothing out of the rear. the front bleeds find can you help me
Oct 28, 2008 at 5:04 AM
RHALL77
  • 3,361 POSTS
check and make sure the bleeders are not plugged
Oct 28, 2008 at 8:45 AM
SWILLIAMS
  • 597 POSTS
Also check the proportioning valve is locked open. It probably shifted to the side that lost the line and is stuck there. You need to center it so fluid will flow. If you don't have ABS it will be directly below the master cylinder. If you have ABS it is in one section of the ABS controller. Either way you use a tool to hold it centered while you bleed the brakes.
Oct 30, 2008 at 4:38 AM
