1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I keep getting a multiple misfire code. I have changed the plugs, plug wires, rotor, and the distributer cap. Do you have any other suggestions to fix this problem?
Sunday, April 19th, 2009 AT 8:53 PM
OBXAUTOMEDIC
MECHANIC
Check for vacuum leaks, check IAC (Idle Air Control Valve), Fuel Pressure, Compression, and Injectors.
