Recheck the sparkplug wires connection-check the compression and injector for no.4 cyl
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
SPONSORED LINKS
Wednesday, May 21st, 2008 AT 3:21 PM
