Line
C
  • 1996 CHEVROLET BLAZER
My metal brake line rusted through causing my brakes to go out and all my brake fluid to spray every where. I have purchased a new metal brake line I need step by step instructions to repair this so it does not happen again and its done right. Can you help me?
Tuesday, June 16th, 2009 AT 9:44 AM
SWILLIAMS
  • 597 POSTS
For instance if it rusted through in one spot, all of the line is likely suspect for the same thing (VERY COMMON) In that case you would be better off replacing the entire brake line from front to rear, the rear rubber line and the rear brake lines to both sides. Then bleeding the entire brake system.
You would need the proper sized line, the proper end fittings and a good double flaring tool. Add in the flare wrenches and brake tools as well if you don't already have them.
As for the steps, bend the line to fit properly, cut the line square and deburr it very well, then add the proper fitting and double flare the line. Install the line and repeat the process on the other end. If your replacing only a small section you will be doing this process 4 times. (Twice for each end)
Friday, March 19th, 2021 AT 12:35 PM
