1996 Chevy Blazer leaking coolant
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
NICOLA6
I have coolant leaking on the top of the engine. drivers side. I 'm not sure where it is coming from. I know its not coming from a hose or thermostat housing. Could it be the intake manifold gasket? There isn't any coolant in oil.
Feb 16, 2008 at 4:04 AM
BLACKOP555
  • 10,386 POSTS
keep wipping on it untill you trace the coolant back to its source if its on the manifold it is probably cracked, but if its near the base its most likely a gasket.
Mar 21, 2008 at 10:57 AM
