Tires and Wheels problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I have a blazer and I need to know how to change the 4-wheel drive front difrental cable?
Wednesday, February 11th, 2009 AT 12:54 PM
MIKE H R
MECHANIC
The 4 wheel diferental cable is located under the skid plate on the side of the housing. It is connected by three bolts. Remove the bolts and you will be able to get to the shift cable to replace.
