Fuel filter is located on the fuel rail.
To locate the inline filter, follow the fuel line back from the throttle body unit or fuel rail. In-line filters are often mounted to the frame rail underneath the vehicle. It may be necessary to raise and safely support the vehicle using jackstands in order to access the filter.
Properly relieve the fuel system pressure.
Using a backup wrench (where applicable) to prevent overtorquing the lines or fittings, loosen and disconnect the fuel lines from the filter. Be sure to position a rag in order to catch any remaining fuel which may escape when the fittings are loosened.
Remove the fuel filter from the retainer or mounting bolt. For most filters which are retained by band clamps, loosen the fastener(s) and remove the filter. For some filters it may be necessary to completely remove the clamp and filter assembly.
Thanks for using 2CarPros.com!
May 8, 2009 at 6:01 AM
