1996 Chevy Blazer Fuel Pressure. regulator or pump?
155,000 MILES • 6 CYL • 4WD • AUTOMATIC
RZMNCO
At turn key it has only 30 psi but when it runs it has 65 psi. also how could i test the fuel pump alone?
Jul 10, 2008 at 1:16 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0ed0f42d31="rzmnco"]Engine Mechanical problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic 155000 miles
At turn key it has only 30 psi but when it runs it has 65 psi. also how could i test the fuel pump alone?[/quote:0ed0f42d31]
What exactly is the problem you are having? We cannot give diagnostic help without know the problem.
to test fuel pump and regulator check out this video...
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Jul 10, 2008 at 2:38 PM
