1996 Chevy Blazer frustration!
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
MR AWESOME
My Blazer is reving up to about 2500 rpm's when I put it in park sometimes. It also will go about 40 miles an hour without me touching the throttle. It will lunge forward as soon as I take my foot off the brake. I changed the idol control valve per advice from a shop here in town. Obviously did not fix the problem. EGR maybe??? Im at a loss at this point. HELP???
Apr 21, 2010 at 7:26 AM
RHALL77
  • 3,361 POSTS
check your throttle plate and make sure it isnt sticking open. also is there a check engine light on? if so, do you have the codes?
Apr 22, 2010 at 7:04 AM
