1996 Chevy Blazer Engines Harmonic Balancer Timing Marks
113,000 MILES • 6 CYL • 4WD • AUTOMATIC
PROBOWHUNTER1959
This engine is a 1995 Chevrolet Vortec 4.3 liter V6 installed in a S10 4dr, 4 wheel drive blazer. The Harmonic Balancer that is used on my engine has 2 timing marks. The Harmonic balancer is not marked in any way shape or form. Short of tearing apart the engine, how do I tell which is the correct timing mark to use for dropping in the Distributor at it correct timing position. I installed the distributor at one of the positions and the engine tried to fire but was back firing severly( i figured it was off by one tooth on the cam), so I repositioned the timing marks. The engine fired (but has slight missfires) the second time around. The engine now keeps coming up with a P1345 code (Crankshaft/Camshaft correlation fault). Do I possibly have the distributor in the correct position and there is something else wrong? How do I tell which is the correct timing mark on the Harmonic balancer?
Nov 2, 2009 at 1:53 AM
  • 110,248 POSTS
To determine which mark is TDC, the only thing I can think of is to remove the #1 spark plug, place a screwdriver into the cylender and turn the crank until the piston is at the top. Whichever line is facing TDC is the one you need.
Now for the code, make sure the crankshaft sensor wasn't moved, damaged, or dirty.
Let me know what you find.
Nov 13, 2009 at 3:32 AM
PROBOWHUNTER1959
Hi:
Thanks for responding. I found that the 2nd timing mark in rotation on this engine was top dead center and that the distributor was in correctly. As for the Code P1345, I found rust particles being held to the Cam sensor by it's magnitism. It totally stopped the cam sensor from working and it set the code P1345(Crankshaft/camshaft correllation fault). The computer couldn't read the cam sensor and set a default so the engine would run (ran very poorly, but it ran). Corrected problem and engine runs great now. Thank you again.
Nov 13, 2009 at 7:45 AM
