1996 Chevy Blazer Engine does hold temperature
BARRY KNOBLE
Other Category problem
1996 Chevy Blazer V6 All Wheel Drive Automatic 115000 miles
I replaced the theromstat and the engine still does not come up to operating temperature
Dec 8, 2007 at 4:53 AM
DENNYP
  • 1,824 POSTS
make sure your coolant is clean and in good condition for your climate.If it is good,you might just have an air pocket in the system.You can solve this by removing the thermostat and filling the coolant until it comes out of the opening,then reinstall the thermostat.After that,top off the coolant and test drive.Let me know if this helps. :)
Dec 8, 2007 at 5:12 AM
